BreakPoint
Monthly Bugs, September 2012
Continued from the August 2012 bugs thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 9
(14,456 Views)
See this bug found here. The icon editor does not center the cursor over some icons when selected. CAR 369132
Message 2 of 9
(14,422 Views)
http://forums.ni.com/t5/LabVIEW/quot-alarm-and-event-display-quot-crashes-my-application/m-p/2143430
It seems, that the Alarm and Event Display (DSC) crashes the application, when the alarm being viewed using the Property Window of this display (double click on the alarm item) disappears (when the value returns to the normal non-alarm range and the alarm is set as AUTO ACK).
May be reproduced using the Example: Toolkits and Modules -> Datalogging and Supervisory Control -> Applications -> Boiler.lvproj) in the following way:
- set the flows so that the tank level returns an alarm (for example tank overflow),
- set the flows so that the level starts to change in the direction of non-alarm range,
- before the alarm auto acknowledges itself, double click on the alarm item in the Alarm and Event Display (this opens the property window) and just observe. When the alarm auto acknowledges itself the whole application (LabVIEW) just crashes.
Happens both in the LabVIEW developement environment and in the executable.
Message 3 of 9
(14,390 Views)
In LV 2012 the property "plot area size" of Mixed Signal Graphs changed its behavior: not only resizes the plot area, but also the graph.
See here. CAR #371045
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 4 of 9
(14,274 Views)
This is happens in 2012. I have not tested older versions.
Bug? Format choices sometimes don't agree with the data type
Message 5 of 9
(14,231 Views)
CAR 369125
Right click menu not behaving properly with right mouse button
_____________________________
- Cheers, Ed
Message 6 of 9
(14,153 Views)
See here.
Ben
Message 7 of 9
(14,100 Views)
See here.
Ben
Message 8 of 9
(14,094 Views)
September is over. Let's continue in the October 2012 bug thread.
This thread is now closed.
Message 9 of 9
(14,038 Views)
