BreakPoint
Monthly Bugs, September 2015
Continued from the August 2015 bug thread
 The posting rules are as always:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 9
(13,697 Views)
SubVI does not correctly return a boolean value to the calling VI.
Discussed here
Message 2 of 9
(13,681 Views)
When your screen resolutlion is less than 1024 pixels high, the new, improved array display does not center correctly in the probe window.
No CAR known yet.
Odd View of Array Probe
Message 3 of 9
(13,650 Views)
Car 546917
Poorly documented IPE help, with incorrect example image, and unclear terminal names.
Message 4 of 9
(13,454 Views)
CAR #544435
Oddness with probeing arrays, on various screen resolutions.
Message 5 of 9
(13,415 Views)
CAR 543507
Using the mouse scroll wheel, on an array, can cause LabVIEW 2015 to crash, if the element the mouse is over, is not the element currently with focus.  Occurs in both edit, and run time environments.
Message 6 of 9
(13,376 Views)
Supposedly CAR 488710 was fixed in LV 2014 SP1 and 2015, but the problems explained in this thread and this thread are still present as of LV 2015.
Listboxes (both single and multicolumn) do not update some internal value when value is changed and keystrokes are used to navigate the selection.
Message 7 of 9
(13,316 Views)
Continued in the October 2015 bug thread.
This thread is now closed.
Message 8 of 9
(13,266 Views)
CAR 544435 has been fixed in LabVIEW 2016. Please see the LabVIEW 2016 Bug Fix List for more information.
Message 9 of 9
(12,011 Views)
