04-02-2015 10:37 AM
@PiDi wrote:
It's never the client responsibility to make sure the
toolkitsupplier code* works. The supplier should make sure that the client knows how to use his code without problems...simply don't let anyone break anything.
I do not agree with this and to some extent is is laughable that your code cannot be "broken" by anyone. Lets speak about DAQmx for a second.
Lets say I drop down a DAQmx Start Task.vi. My VI is broken because an input is required. So I create a constant and run, but I get an error because the task is empty. In the users opinion the software is broken and doesn't do what they intended. As the developer I say they didn't use it right and reading the documentation of the function, and the error should make it clear that they did something wrong.
Similarly if I provide some code to someone, with an Init, Read, Close, and they leave out the Init, and just use a Read with a constant, it will likely break. That init needed to do things that the Read needs, and the help and error should make this clear.
I still think OO is a good thing, especially for modular code similar to a toolkit, I just don't agree with your reasoning.
You say you don't like the term toolkit because it is a "specific entity where someone during developement had to weight reliability and capabilities - and sometimes the latter would win." Isn't this all software?
Also your link is broken.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
