BreakPoint
Regular Expressions Board
It worked for me.
23790iF8AE4059C5DBD8D4
Jim
Message 21 of 150
(14,232 Views)
Thanks Jim,
I was using the "Search and Replace Pattern VI" with TRUE wired to "replace all?"
It did not replace any.
I will convert (create a subvi) using the while loop as you showed and I'm sure it will work.
I wonder if I stumbled onto a bug with LV2010...
R
Message 22 of 150
(14,224 Views)
I didn't even think to try that, but it worked for me.  I just deleted the While Loop and wired the Boolean constant.
23794iFBC83965123EF33A
Have you right-clicked the node and checked "Regular Expression"?
23796i1AF387017E031FD7
Jim
Message 23 of 150
(14,219 Views)
d'Oh!!!
I wasn't using the Matche Regular Expression!!
I was using this one!
Well, it partially worked...  😉
Message 24 of 150
(14,198 Views)
I used Search and Replace String, not Match Regular Expression.
Jim
Message 25 of 150
(14,191 Views)
I've posted another Regexp solution here which explains the following expression: (-?[\d]+\.?[\d]*)|(-?\.[\d]+).  I used it to extract numbers from a string.
It made me think of the expression, "If the only tool you have is a hammer, you tend to see every problem as a nail." ~ Abraham Maslow
Jim
Message 26 of 150
(14,075 Views)
Regular Expressions: Now you have TWO problems
Lots of interesting info and tools listed in the Coding Horror blog post. What about LabVIEW?
I needed to process a bunch of old TestStand 1.0 and 3.0 HTML reports for import into a database. I thought, what a great way to learn regular expressions!
After some research, I kept reading "you can't use regex to parse HTML". Since I had structured HTML in two different flavors (basically out of the box reportgen_html and a couple of additions to the header) I tried anyway and came up with this. I had to parse the data further, but that was specific to my application. This VI was used to clean the HTML tags.
Message 27 of 150
(14,025 Views)
Thanks Philip,
I will probably borrow from your code when I get a chance to return to the project that I was working on and posted earlier in this thread.
You should submit this for the example code contest.
Message 28 of 150
(14,011 Views)
See here for an example to toss bad nodes in a VRML file.
Two solutions offered are;
and
Ben
Message 29 of 150
(13,846 Views)
I answered this question:
@emyh wrote:
[...] have: C1-C10
(C1-C10 means there are actually ten cmponents; C1, C2, C3...C10)
I now want to convert the array containing C1-C10 into an array looking like this:
C1
C2
C3
C10
... with this Regexp:
Read the Regexp like:
  • ([A-Z])  find an upper case alpha-character and store it in a backreference
  • ([0-9]+) find one or more digits and store it, too, in a backreference
  • - find a "-"
  • (\1) find what was found in the first backreference.  In this example it will find a "C" at the beginning and search again for a "C"
  • ([0-9]+) find another one or more digits and store it in a backreference
I'm only using one of the backreferences, but the others are so I can expand the node and get at each of them (in order of appearance in the regexp).
Jim
Message 30 of 150
(13,658 Views)
