BreakPoint
Rube Goldberg Code
altenbach wrote:
How would the lame brute force code perform when implemented in G? 😄
Let's just say that the File I/O would no longer be the rate determining step.  Smiley Wink
Message 1041 of 2,635
(10,736 Views)
No VI descriptions - marks deducted for CLD
Regards
Ray Farmer
Message 1042 of 2,635
(10,698 Views)
@altenbach wrote:
@Darin.K wrote:
Maybe he means "real"programmers. Smiley Tongue
"Real" programmers use switches and patch cables.
Looks like my basement...
Message 1043 of 2,635
(10,698 Views)
one could kill for a basement that sizeSmiley Very Happy or even a basementSmiley Sad
Regards
Ray Farmer
Message 1044 of 2,635
(10,684 Views)
At least they are looking at the help that ships with the system instead of posting something like "Help my lebview give error?" to the forums. I hope one of them is reading the style guidelines. That is WAY too many wire bends.
[Edit: Why is that man on the right wearing a dress?]
LabVIEW 2012
Message 1045 of 2,635
(10,681 Views)
(J. Edgar Hoover...?)
Just kidding. There were quite a few women deeply involved in the design of the ENIAC.
Message 1046 of 2,635
(10,663 Views)
One could use a For Loop with autoindexing turned on.
Alternatively, let's use a while loop, but add a select statement with a First call primitive (since the shift register is uninitialized this almost makes it act like it was initialized).  But incrementing the shift register isn't enought, let's feed it through the Quotient & Remainder function.  Seen here.
Message 1047 of 2,635
(10,574 Views)
"What was the developer thinking?" is my first reaction.
Wouldn't a "delete from array" and use the deleted value do the smae thing?
Ben
Message 1048 of 2,635
(10,541 Views)
I just realized that path to string is polymorphic, so a loop isn't needed at all.
Message 1049 of 2,635
(10,532 Views)
Maybe the CLD exam or CLA exam should include a section on how to interpret heavily Rubed code...
After all, if you're a consultant/contractor, that's what you often see out there..
Message 1050 of 2,635
(10,526 Views)
