BreakPoint
Rube Goldberg Code
@JÞB wrote:
For the first, a 0 iteration for loop outputs default data ftor the type of any output tunnels.
You get the same with a case that uses output tunnels that are set to use default if unwired. (but that was not available many (many!) versions ago. How old is this code?)
The ">" construct on the button labeled "Zero" probably means that the mechanical action is not latch. Thus the need for detecing a FALSE>TRUE transition. The incorrect latch action could mean that there are local variables and value properties elsewhere.
And yes, the "AND TRUE" is of course a noop, just returning the other input inchanged.
It is difficult to judge code from two small cropped sections and verbal descriptions. If you think we could contribute with more tips, feel free to post some of the VIs.
Message 1791 of 2,641
(11,587 Views)
@markconigliaro wrote:
Being new though, I have to ask is there something I'm missing? Are these old school techniques or is there actually some purpose to these that I'm missing?
The person who developed the code was either a bad programmer, or far too inexperienced for the task.  I'm not saying all programmers who use 1 iteration loops are bad, there are reasons (few and likely not this case but still).  But if you are and'ing a boolean to a constant...then you need to take CS 101, or Digitals 101, or a high school electronics or computer class.  Anyway feel proud of yourself being able to recognize code smell.
Message 1792 of 2,641
(11,581 Views)
It's nice to know I'm not crazy. I'll be back in the office on Tuesday, where I'll post a bigger sample of some loops that have a bunch of these kinds of things combined.
I can say some things from memory though. Jeff, the for loops have no outputs. They're all just a single iteration for loop that generates a number or turns something on/off. And altenbach, all buttons are set to "switch until released", and I can't post "some of the VIs" because it's 1 huge, massive VI with no subVI's at all! I don't think a 60 inch TV/monitor would be able to show the whole thing.
Message 1793 of 2,641
(11,561 Views)
I have to commit that I sometimes use the 'and with a boolean constant.
In cases where you want to debug some code and you have a Init/Firstrun input , the 'AND with boolean constant'  is a nice way to overrule that input.  After debugging one could have deleted it , but simply leave the constant TRUE usually doesn't hurt.
Greetings from Germany
Henrik
LV since v3.1
Message 1794 of 2,641
(11,547 Views)
One plausible reason that someone put in an AND TRUE is that they were ANDing with some other condition in the past.  Perhaps they need to force that to be true while debugging or modifying their logic.  Eventually, they got to a point where they never needed to put the other logic back in, but never got around to stripping that out and now it is just an artifact left over from previous code.
Message 1795 of 2,641
(11,526 Views)
In cases like those I usually use a disabled diagram structure, and have a case where there is a true constant, I might then put the #debug bookmark in the case as well.  If you did choose to do it your way you could still place a code comment stating what you are doing and it would justify the odd looking bit logic.
Message 1796 of 2,641
(11,496 Views)
I ran into this one in some legacy code I inherited.  It was to convert data coming back from Modbus into floating point...
Message 1797 of 2,641
(11,477 Views)
Careful.  Notice that the 0 index was not used.  So you need to delete that element before you rotate.
Message 1798 of 2,641
(11,471 Views)
You are correct, sir.
The lower snip came from my code.  I'm using a newer Modbus package.  The old one returned an array of u8 with element 0 being the number of bytes per data point.
The new one just returns an array of u16.  I should have modified it to be identical before posting though 🙂
Message 1799 of 2,641
(11,463 Views)
If you have an array of U16, then you only rotate 1 element.  Or you could use Reverse 1D Array.
Message 1800 of 2,641
(11,458 Views)
