BreakPoint
Rube Goldberg Code
@JÞB wrote:
There is something wrong with your cleanup settings.  The For loop grew(should have shrunk and the i term is wrongly placed), wires are on top of each other and the int wires cross twice.  Tell me that was not a Ctrl+U result
It was a click on the cleanup button in the toolbar, nothing else. I won't spend time manually cleanup anything like that. 😄
Also, since I don't use cleanup for my own code, all settings are at their default. 😮
But yes, I agree it did not do a great job... and clicking cleanup a second time makes it even worse.....
Message 2041 of 2,641
(11,615 Views)
... and look what cleanup (LV 2018) does to his client code:
Strangely, if I do a ctrl+a , ctrl+c and copy it into notepad, things no longer overlap in the pasted image, so go figure. 😮 Also, a second cleanup push fixes the overlap.
Message 2042 of 2,641
(11,614 Views)
The code MUST have autogrow off on some structures
Message 2043 of 2,641
(11,612 Views)
Autogrow on the while loop is enabled.
Message 2044 of 2,641
(11,608 Views)
I always maintain that if the cleanup tool makes your block diagram look BETTER, you should really revisit your coding practices.
Bill
CLD
(Mid-Level minion.)
Message 2045 of 2,641
(11,544 Views)
I know this isn't really the place for serious questions, but does Autogrow affect the behaviour of the auto-cleanup? And if so, how? (Why?!) (Assuming that either nothing is selected, or the entire diagram, etc)
Message 2046 of 2,641
(11,536 Views)
Actually, it is the other way around!
BD Cleanup affects almost everything (except, maybe, comments)!
If you have any structure with Autogrow enabled, BD Cleanup would still reduce the size of this structure if it it unnecessarily/unusually big/large.
- Partha ( CLD until Oct 2027 🙂 )
Message 2047 of 2,641
(11,532 Views)
And (I presume) structures that have "Exclude from Diagram Cleanup?" turned on...
Message 2048 of 2,641
(11,460 Views)
I have seen a difference with that one 🙂
Message 2049 of 2,641
(11,450 Views)
That's obvious!
Message 2050 of 2,641
(11,446 Views)
