BreakPoint
Rube Goldberg Code
yeah... but the one on the left looks more impressive to the boss.
Bosses are impressed with highly complicated looking code.. 😮
......  -sigh -  ............
Message 291 of 2,641
(13,247 Views)
That reminds me of a story I read once about how they told developers at Apple to document the lines of code they wrote each week to measure their productivity. Naturally, the developers didn't like this, so when one of them optimized a specific module and made the code much simpler, he happily wrote "-2000 lines". Smiley Very Happy
___________________
Try to take over the world!
Message 292 of 2,641
(13,243 Views)
Suggested to change shift registers and use an array to simplify code..
Message Edited by JoeLabView on 07-08-2008 06:25 PM
Message 293 of 2,641
(13,207 Views)
Miniature Goldberg..
From: http://forums.ni.com/ni/board/message?board.id=170&thread.id=340341
Message Edited by JoeLabView on 07-13-2008 10:03 PM
Message 294 of 2,641
(13,148 Views)
Given the amount of empty whitespace in that for loop, I don't know if I'd call that "miniature"
Message 295 of 2,641
(13,103 Views)
I have just noticed that a dot is shown for most of the wire junctions (Show dots at wire junctions property seems to be checked) but not for all. How is this possible ? A display bug ?
Message 296 of 2,641
(13,073 Views)
Maybe the picture was edited in MS Paint or some such editor, and the dots were forgotten.
--Robert
Message 297 of 2,641
(13,063 Views)
No, i don't think that the dots were removed externally.... i think more about something like this:
You can see that the wires are very close to each other, moving the wires one pixel closer would create the dot. But sometimes, it does not show up. So the "dot" would be located in the indexing tunnel then....
Btw, this sometimes happens when using the  "clean up wires"-function.....
Norbert
Message Edited by Norbert B on 07-16-2008 02:55 AM
Norbert
Expert: Geometry
Message 298 of 2,641
(13,060 Views)
I would go with the Paint answer as well. If you look in the original thread, you can see that the piece of code on the bottom doesn't exist, so it was added separately (you can see it doesn't even line up) and since the VI wasn't supplied, image editing is the logical conclusion.
Additionally, if you do what Norbert did, the one pixel shift is clear and in that image it's not visible.
___________________
Message 299 of 2,641
(13,054 Views)
Could two overlapping tunnels could look like this.
Ben
Message 300 of 2,641
(13,041 Views)
