BreakPoint
Rube Goldberg Code
Coq rouge wrote:
So much for Mr. nice gay
I'm sure you meant "Nice Guy"
We should get back to topic... Rube Goldberg code.  🙂
Message 511 of 2,635
(12,206 Views)
I got this one today from a customers vendor!
It is the equivalent of a text and ring indicator! Smiley Very Happy
I have to admit though- I've never seen a transparent tab control before.
Message Edited by Jeff Bohrer on 07-02-2009 09:56 AM
Message 512 of 2,635
(12,115 Views)
...can't see it with 8.5 😞
Never say "Oops." Always say "Ah, interesting!"
Message 513 of 2,635
(12,110 Views)
saved to 8.5
Message 514 of 2,635
(12,104 Views)
Wow, what a code monster. You might want to resize the FP so the next button actually shows. "As is", the program cannot be operated or stopped in any obvious way once it's run.
Message 515 of 2,635
(12,107 Views)
I thought it was just me that I couldn't find the Next button.
How did they come up with that icon.  What a blobby mess.  It kind of looks like the way TV's are now that they have "improved" them to be all digitally broadcast.
Message 516 of 2,635
(12,102 Views)
I was amazed as well!  My favorite WTF is still the ICON! I intentionally left everything except the photos vi name and text EXACTLY as published in the original (rev 335 Smiley Very Happy ) that I recieved to increase your joy!  My hair stood on end when I opened the viSmiley Surprised
Message 517 of 2,635
(12,093 Views)
Jeff Bohrer wrote:
...(rev 335 Smiley Very Happy )...
Maybe you should track down the other 334 revision and make them into a sequential movie to be posted on youtube. 😄
Message 518 of 2,635
(12,092 Views)
I think that might actually cause death from ruptured solar-plexus(s) (-plexi?) Smiley Very Happy
Message 519 of 2,635
(12,085 Views)
Sometimes we don't even need to see the diagram to tells it's Rube Goldberg code.
I must say, the detour via arrays, DBLs and Clusters is very, (very!!!) scenic. 😄
ksin wrote:
This is the data read from the buffer but displayed as Hex '0103 0427 D241 C1A1 7E'. I'm currently using:
1) a 'String to Byte Array' then
2) push it through a 'To Double Precision Float' then
3) go through two 'Array Subset' to pull the data that I wanted (which is really 27D2 and 41C1) then
4) convert each array to cluster and extract each element, after that
5) need to calculate/convert the data that I wanted to a float.
41C1 is the high word and 27D2 is the low word.
Suppose to use the high and low word to get the SIGN, EXPONENT and MANTISSA and use those to calculate the float which in this case should be 24.14444351.
I know this is really a very long process but I have not figured out the easy way yet.
(seen here)
Message 520 of 2,635
(11,956 Views)
