BreakPoint
Rube Goldberg Code
Well, I can see that for people that have been on this forum for a while there's no problem, but for new people, they could take it the wrong way. Anyways, my comments where just meant as a concern, nothing moreSmiley Happy
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 1031 of 2,635
(11,529 Views)
We all see the odd piece of hair raising code - like some of the recent posts, but I do think that some of the snippets called out as Heath Robinson constructs are just small optimisations rather than a case full blown over-engineering.
- Boolean==True? Could be overlooked remenants of refactored code
- Dividing by zero to generate a NaN constant; it isn't entirely obvious you can just enter NaN. The compiler will convert it to a NaN constant anyway; nothing lost and nothing gained.
 And so on.
- Cheers, Ed
Message 1032 of 2,635
(11,516 Views)
Why does it need a subVI and two sub-subVIs (= 3 VIs!) to basically implement the following code functionality ????
If you don't believe me, have a look at the UI challenge template 😄 Here's the original.
Sure, the original is better documented (especially all the "multiplies"! ;)) , modularized, and structured. 😄
Message 1033 of 2,635
(11,429 Views)
Nicely documented but I understood what the multiply did the first time. I was pretty sure that the other two did the same function as the first but it is nice to see how they hammer it in. Now I will never forget what the function with the multiplication symbol on it does! Smiley Very Happy
LabVIEW 2012
Message 1034 of 2,635
(11,373 Views)
That was done for text-based programmers so they wouldn't be all confused. Smiley Very Happy
Message 1035 of 2,635
(11,337 Views)
But it is not complete. Shouldn't the diagram constant have a label with "one half". 😄
Message 1036 of 2,635
(11,326 Views)
You mean "normal" programmers. Smiley Tongue
Richard
Message 1037 of 2,635
(11,325 Views)
Maybe he means "real" programmers. Smiley Tongue
(I am just bitter because I wrote some beautiful code for the other challenge in G and it is slower than the totally lame brute force code I wrote in C just for the heck of it. )
Message 1038 of 2,635
(11,308 Views)
@Darin.K wrote:
Maybe he means "real"programmers. Smiley Tongue
"Real" programmers use switches and patch cables.
Message 1039 of 2,635
(11,308 Views)
How would the lame brute force code perform when implemented in G? 😄
Message 1040 of 2,635
(11,304 Views)
