BreakPoint
Rube Goldberg Code
http://forums.ni.com/t5/LabVIEW/Need-help-parsing-a-string/m-p/1956895#M649828
A perfect example of why to think before you code. My first solution, and second solution, only minutes apart...
Message 1131 of 2,635
(12,138 Views)
Great. Lean and clean!
Message 1132 of 2,635
(12,099 Views)
RG machines... this is pretty cool:
http://www.wimp.com/machinesnothing/
Message 1133 of 2,635
(12,052 Views)
I found this in a system I support.  Am I missing something?
Jim
Message 1134 of 2,635
(12,003 Views)
Smiley SurprisedSmiley SurprisedSmiley Surprised
I think the original intent was to fill up a block diagram-  your solution misses on that point. (I wonder what happens in year 201A?)
Message 1135 of 2,635
(11,998 Views)
Yes, the warrenty regarding data integrity.  You have obviously broken the seal on the "Data Manipulation" palette.
Ben
Message 1136 of 2,635
(11,990 Views)
Just curious, I'm trying to grasp why this works, but if you do the same with two decimal numbers, say 10 and 20, you obviously don't get 1020 out. I'm assuming it has to do with joining two U8's to a U16 and hex is base16 but even after writing out the bits and the OR to try to further understand, I still can't wrap my head around it. Clarifications please.
Message 1137 of 2,635
(11,976 Views)
Looks to me like the numbers are encoded in BCD?
Message 1138 of 2,635
(11,968 Views)
The date is stored in our device's NVM in a human-readable format when viewed in a Hex editor.
I forgot to mention that this was part of a system we paid hundreds of thousands of dollars for.  😛
Jim
Message 1139 of 2,635
(11,947 Views)
It's obvious why it costs hundreds of thousands of dollars, if they need to code this thing to concat two numbers.  Smiley Very Happy
Message 1140 of 2,635
(11,910 Views)
