BreakPoint
Rube Goldberg Code
@altenbach wrote:
(seen here)
Try to simplify this while loop 😄 😮
(It is important to know that the "array" indicator gets reset to default upstream somewhere in an earlier frame of a long flat sequence.)
I'll take that as "Maintain the Values and size of array as is"
Who needs a loop?
Spoiler
Message 1521 of 2,635
(11,096 Views)
Who needs a loop?
I didn't check the code, but I expect your version is actually incorrect (Jeff, you shouldn't be failing these classic CLAD questions Smiley Surprised ).
I think a simpler option is (array size+2) into a for loop and simply output the i as auto indexing, which I expect would perform better than your code, because there are fewer operations.
Now, whether those two extra elements are actually desirable or there from lack of understanding is another matter.
___________________
Try to take over the world!
Message 1522 of 2,635
(11,077 Views)
I would just use the Ramp function...
Message 1523 of 2,635
(11,056 Views)
oh ye of little faith. you missed that the wire out of riffle via is an index
Message 1524 of 2,635
(11,033 Views)
oh ye of little faith. you missed that the wire out of riffle vi is an index. Useful function that riffle vi
I like to show it off now and then.
Ramp would be the best choice. I figured someone else would demonstrate it
Message 1525 of 2,635
(11,029 Views)
I think Yair's point was that the original RG code actually creates an output array that is two sizes too large. The loop only stops after [i] > N. Of course this is incorrect for the application where it was originally used, but in order to make your code equivalent, you need to add two elements. 😉
Message 1526 of 2,635
(11,044 Views)
Yup, I totally overlooked the silly logic and wired that as a "less than" in my head
Message 1527 of 2,635
(11,033 Views)
I found this gem in some old company code today.  Because using Typedefs and enums is too easy.  Oh and shift registers.
The best part is that's barely even scratching the surface of what's wrong with this code.
Tim Elsey
Certified LabVIEW Architect
Message 1528 of 2,635
(10,958 Views)
Well at least they knew they could use the scan from string to perform the string to enum conversion.  I've seen many developers not know that...but yeah they should know that you can have an enum constant.  Oh but I bet that the compiler is smart and does constant folding to replace the string constant with an enum constant...not that it makes it any better.
Message 1529 of 2,635
(10,953 Views)
I like it!!
Although I would go so far as to suggest that this would not necessarily be a Rube every time. If you have 2 enums, one of which is applicable to this VI, and one of which is applicable to the whole project (or multiple projects) then the values in the eunms might not be the same even though you can guarantee 2 cases the same.
as I said, I like it... in the right circumstances it has its place! (probably just not where you found it!
James
<edit> (by it I mean the method of converting an enum via a string back into an enum!)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 1530 of 2,635
(10,888 Views)
