BreakPoint
Rube Goldberg Code
@parthabe wrote:
Today's delight! 🙂
Stern Warning! When there is no error from the H/W, you should be extra careful with the way you code. 😉
The case structure only looks at the boolean part of the error cluster. If the wire has a warning (false + error code), this code will reset it.
I don't know if that's the actual intended case, though.
___________________
Try to take over the world!
Message 1541 of 2,635
(11,063 Views)
@parthabe wrote:
Today's delight! 🙂
Maybe if things work properly then warnings will be generated, and you want to clear it?
EDIT: Beat again.
Message 1542 of 2,635
(11,062 Views)
Edited: Ignore Post, didn't read the next page... 🙂
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 1543 of 2,635
(11,040 Views)
But that's why we have the "clear errors" primitive.
No need for case structures, tunnels, selectors, diagram constants, etc. (Well, they are still all there, just inside a system VI :D)
Message 1544 of 2,635
(11,023 Views)
I think the clear specific error primitive is very recent...    I don't have it, and I'm running LV 2012.
(I acutally do have a clear specific error vi in my user library, and have always wondered why NI didn't have it included themselves... )
Without the new primitive, the shown way does seem to be a fast and clean method to remove the warnings.
Message 1545 of 2,635
(11,017 Views)
But you have the clear all errors (same, but without the upper input), which is similar to what is discussed here.
Personally I would probably have left out the diagram constant and used a "use default if unwired" output tunnel. 😉
Message 1546 of 2,635
(11,021 Views)
AFAIK, there is no Clear Specific Errors VI. There is only a Clear Errors VI, and it is available in LV 2011 also.
- Partha ( CLD until Oct 2027 🙂 )
Message 1547 of 2,635
(11,016 Views)
Yup Clear Errors has existed since at least 2011.  Clear errors selectivly exists in 2014 nativly.  Of course OpenG and MGI have had their own versions of filtering errors for a while.
Message 1548 of 2,635
(11,002 Views)
It is there in 8.5 also. If I remember correctly, it was there in 7.x as well.
Message 1549 of 2,635
(10,985 Views)
Looks like it was introduced in 7.0. 🙂
http://labviewwiki.org/Error_handling
Message 1550 of 2,635
(10,981 Views)
