BreakPoint
Rube Goldberg Code
@thoult wrote:
@tst wrote:
@Ben wrote:
After asking 8 LV developers, 6 of which are CLA's NONE of us knew that.
By now I'm so used to LV's widespread polymorphism with certain types of functions, that I'm usually only surprised when I try something like this and it doesn't work.
This. I also get irrationally annoyed when it's not!
Yep me too. Even some (what I think should be) fairly trivial functions don't let me bung arrays into them (can't recall any off hand though). Makes things nice and messy for me.
Message 1581 of 2,635
(11,137 Views)
Seen here.
Message 1582 of 2,635
(11,007 Views)
If the array is twice as long as it should be, we would typically use the array subset function.
Apparently, there are better ways (if you are paid by the diagram area and raw amount of code). 😄
(seen here)
 There are quite a few RG elements. Can you find them all?
Message 1583 of 2,635
(10,948 Views)
Actually, that would be a Decimate 1D Array (they ar keeping every other element).
Message 1584 of 2,635
(10,943 Views)
Yes, you are possibly right. However, a decimation would be incorrect for the convolution problem at hand. He needs to take the array subset.
I thought maybe the wire is actually connected to the IQ terminal (with some wire bends under the node), which could easily be the case judging from the mess of the other wires. 😄
Message 1585 of 2,635
(10,938 Views)
That wouldn't halve the array size (unless N=4) So the thing is both RG Rich and fails to meet requirements (OOPS- That happens with "Richly Obfuscated" code)
  • Case Selector driven by Comparison of an integer
  • Case could be replaced by Conditional tunnel  (Pick one of the above)
  • Loop Unnecessary (Q&R handels arrays just fine and there are so many ways to generate a array if incrementing I32s)
  • Q&R Unnecessary- Base Condition on i++<= N/2
  • Whole darn thing unnecessary- There is an array primitive for that
How did I do?
Edit - I nearly did the "coffee forcefully expelled to monitor" thing when I read your response "You probably should have had a coffee and waited for the second thing"Smiley LOL
Message 1586 of 2,635
(10,846 Views)
Saw this one today.
I suppose it's possible the author could be forgiven since this was originally written in 1999. That's before my time - does anyone know if the Delete From Array primitive did not exist by that time?
Message 1587 of 2,635
(10,757 Views)
I am pretty sure that "insert into array" and "delete from array" are relatively late addition to the array palette. (The matrix things are even newer.)
Edit: Yes, I was right. Just checked my LabVIEW 4.0 installation and it does not have the insert/delete function in the array palette.
Message 1588 of 2,635
(10,749 Views)
You have a LabVIEW 4 installation?! o.O
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1589 of 2,635
(10,698 Views)
/Y
Don't look so surprised.  He also has a copy of LabVIEW 3.
Message 1590 of 2,635
(10,682 Views)
