BreakPoint
Rube Goldberg Code
This is just the tip of the iceberg of the code posted here. The other problems are too numerous to list (almost all terminals disconnected and exclusive wiring via local variables, stacked sequence with 8 frames and 7 sequence locals, while loops with the stop condition wired from the outside, fixed iteration count WHILE loops instead of FOR loops, never heard of "spreadsheet string to array" and using convoluted while loops instead, etc. etc.)
So, let's look at the picture below.
For some reason, we need to get the same "pages" property five times in parallel, each getting the same array result of course, then we need to index out one element from each and writing to the visible property. For some reason this is still not enough, so we need to repeat all that five(!) times in a while loop as fast as the computer allows! Why?????
In the end, we are getting the same "pages" property 25 times and writing each visibility five times with the same value.
Message 1601 of 2,635
(11,191 Views)
You weren't kidding. That is some of the best bad code I have seen in awhile.  He took it to a whole new level
Message 1602 of 2,635
(11,105 Views)
Jeff·Þ·Bohrer wrote
Dont leave dT = 0 you don't have enough memory, trust me ok?
How about machine epsilon?
Message 1603 of 2,635
(11,085 Views)
Lets have some fun with converting strings to timestamps: Get Time Stamp will milli seconds from string time stamp format
Message 1604 of 2,635
(10,872 Views)
Hopefully you realized that your outputs didn't match,wrong AM/PM flag. At least the answer doesn't complicate your code, just change the format string to "%<%m/%d/%Y %I:%M:%S%u %p>T"
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 1605 of 2,635
(10,859 Views)
Yeah, I noticed my %H vs %I issue.  It was just a little too late to actually edit it.
Message 1606 of 2,635
(10,856 Views)
Not quite RGC, but very fitting to the thread title and idea. 🙂 http://www.haneke.net
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1607 of 2,635
(10,755 Views)
That is bonkers - but a good use of a tiled background GIF to ensure continuity of the balls at the edges.
CLA
Message 1608 of 2,635
(10,741 Views)
/Y
That's horrendous. Smiley Mad Should come with a "May induce a migraine. Do you wish to continue?" warning popup.
PaulG.
Retired
Message 1609 of 2,635
(10,731 Views)
@PaulG. wrote:
/Y
I was immediately trying to turn off "hightlight execution" mode. 😄
Message 1610 of 2,635
(10,725 Views)
