BreakPoint
Rube Goldberg Code
VDB_1 a écrit :
World's Slowest Rube Goldberg  Smiley Happy No LabVIEW involved though...
https://www.youtube.com/watch?v=o-c7tBlnFsw
Very nice. Thanks for sharing.
Message 1661 of 2,635
(11,337 Views)
@BowenM wrote:
No more stacked sequence structure?  No problem!
(not quite RG code, but...)
I've done that myself.  It works well for sequenced tasks.  The thing to set this apart from the SSS is to make it so that the loop is stopable (use the Conditional Terminal).
Message 1662 of 2,635
(11,320 Views)
(Seen here)
If a stacked sequence is a good thing, a stack of stacked sequences must be even better 😮
(Fortunately, we can use local variables to avoid all these wires 🙂 Doh!)
(Why do I now have a craving for pancakes? :D)
Message 1663 of 2,635
(11,201 Views)
On a similarly non-LV Rube(ish) theme:
https://youtu.be/8ns4cfMABqQ?t=30s
CLA
Message 1664 of 2,635
(11,197 Views)
I use that as my go to  initialisation sequence method.  Scalable, can use an array of type def'd constants and maintain state with shift registers!!.
I suppose I could use a dynamically launched asynchronous process with messages and all corner cases under the sun covered including EMP blackout to initialise a VI but I consider this a bit "Wordy"
Craig
LabVIEW 2012
Message 1665 of 2,635
(11,140 Views)
@craigc wrote:
and all corner cases under the sun covered including EMP blackout...
Craig
[Edit]
Oops!
Wrong forum.
Ben
Message 1666 of 2,635
(11,105 Views)
@Ben wrote:
[Edit]
Oops!
Wrong forum.
I can easily imagine someone on the prepper forums mentioning something that sounds like "state machine" or "action engine" or "in place" and then having Ben automatically reply with a long post with links to various nuggets and posts by Greg McK. 😉
___________________
Try to take over the world!
Message 1667 of 2,635
(11,059 Views)
I have read those posts and they are all very good nuggets!!
LabVIEW 2012
Message 1668 of 2,635
(11,003 Views)
Oh EPIC FAIL!  The neighbors Dish TV satalite antenna seen at 1:18 was not used.
Message 1669 of 2,635
(10,977 Views)
I wrote one here - http://forums.ni.com/t5/LabVIEW/Disable-Text-Selection-on-FP-Indicator/m-p/3217073#M934245
Jim
Message 1670 of 2,635
(10,901 Views)
