BreakPoint
Rube Goldberg Code
Ran into this code today and it seems to be screeming Rube Goldberg.  Any comments?
Message 1731 of 2,635
(11,982 Views)
I'm not seeing what the simpler alternative would be for this to be a Rube.  Looking at it for a minute or so, it doesn't seem bad.
Message 1732 of 2,635
(11,955 Views)
Sorry Ray but I am with Bill and can not point the RubeGoldbergness of that code. It some ways it is rather clever way to get the index (plus 1) of all of the true bits in a cluster of booleans.
Ben
Message 1733 of 2,635
(11,947 Views)
Ray.R wrote: improveCode.png
The only thing Rubish I see is perhaps the cluster could have been an array from the beginning.  But there are often good reasons for the cluster.
Message 1734 of 2,635
(11,944 Views)
Thanks guys!
I am always looking for ways to improve my code.  🙂
Message 1735 of 2,635
(11,870 Views)
Snap of portion of code
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 1736 of 2,635
(11,840 Views)
What is happening before element 3 in the initial code? Does the equals just not have anthing attached to its output?
Message 1737 of 2,635
(11,824 Views)
Actually its a part of complexcode, just portion of it i thought to share, the output will be passed to another loop.
Message 1738 of 2,635
(11,820 Views)
I would even build the rows 2&3 into a 2D array of strings (or use subset array), do only one single spreadsheet conversion, then index the rows out at the end.
I am also questioning the sanity of using binary formats for DBL. That's typically a thing for integers so maybe the type should be a blue array. Where is the output used?
Of course all output terminals should have self-explanatory names. Most seem to be at the defaults.
Message 1739 of 2,635
(11,806 Views)
You know, this is mainly a fun thread, but we could use it as an excellent tool to post what we think is Rube-ish code and see if anyone can help us un-Rube it.
Bill
CLD
(Mid-Level minion.)
Message 1740 of 2,635
(11,800 Views)
