BreakPoint
Rube Goldberg Code
Yes Ray,
It is "Also known as" from wikipedia
Thanks for the info
Mathan
Message 251 of 2,635
(13,376 Views)
I was using the silent 'n' version Smiley Very Happy
Regards
Ray Farmer
Message 252 of 2,635
(13,372 Views)
Dear Norbert B,
@Patha: WEQ is a definition also made by Altenbach and stands for "Wire Equivalent Code" See message 16 (page 1) of this nice thread 🙂
Nice to call as patha rather than partha. ha ha ha Smiley Surprised
And offcourse it is page no 2 and not 1. Smiley Wink
Mathan
Message 253 of 2,635
(13,366 Views)
Mathan
Mathan,
well, i don't quite get the point of my miswriting of "Partha"... i suspect you are refering to this.
And, of course it's page 1 if you didn't stick with the stupid initial setting of this board. I changed my settings to list 25 messages per page, so this thread takes an overall of 11 pages for all those 254 messages. You can change that on your in the preferences of your profile in the section "Linear Format Settings"....
hope this helps,
Norbert
Message Edited by Norbert B on 05-09-2008 08:23 AM
Norbert
Expert: Geometry
Message 254 of 2,635
(13,342 Views)
OK, guys!
At one point in the distant past this thread was a collection of Rube Goldberg Code. Can we try to keep it that way???
I am all for endless discussions of acronyms and movie sequels, but maybe there should be a seperate thread for all this. 🙂
Thanks!
Message 255 of 2,635
(13,324 Views)
Here, here! Thank you for bringing some sanity back to this thread.
Now, let's see some code!
Message 256 of 2,635
(13,328 Views)
Look at the true case in the VI posted here.
Message 257 of 2,635
(13,291 Views)
And another nice Goldberg found in this thread
Norbert
Message Edited by Norbert B on 05-14-2008 03:23 AM
Norbert
Expert: Geometry
Message 258 of 2,635
(13,236 Views)
I was wondering if this the attached image is a Goldberg.  I think it might be because the global of an indicator is wired when the indicator is right next to it.  The only reason I hesitate is because I found this in an Express VI (hope its not bad to post this part it).  And there is nothing in the False case of the if loop.
Is it a Goldberg?
--Robert
Message 259 of 2,635
(13,125 Views)
Here is the code:
This indicator is actually used to hold the data so that when you open the express VI again you will immediately see the previous data. It is possible that the local was used in an attempt to load the front panel into memory, but that would be useless, since locals don't do that. I suppose it's also possible that the local serves some need in the process of creating the display VI, but if it does, that need is not documented in this code and that's a bit of a Goldberg.
___________________
Try to take over the world!
Message 260 of 2,635
(13,103 Views)
