BreakPoint
Rube Goldberg Code
Interesting idea on how to avoid all errors:
====>   Wire the "Simple Error Handler" before the function of interest. You'll never get an error 😄
(Seen here)
Message Edited by altenbach on 10-28-2008 10:28 PM
Message 331 of 2,635
(12,734 Views)
OK, heres a gem from the same post as above:
Maybe I completely misunderstanding all this, but apparently the programmer simply wants to know the largest of five integers.
Besides the fact that the code is seriously flawed to begin with (and can give incorrect results), does it really need
  1. a diagram constant of "5"!
  2. a FOR loop!
  3. a case structure!
  4. a shift register with five terminals!
  5. a feedback node! (yes! in addition to the shift register...)
  6. a case structure!
  7. a comparison operation!
I would like to see the code if we need to get the largest of 50 integers. 😮
Message Edited by altenbach on 10-28-2008 10:52 PM
Message 332 of 2,635
(12,731 Views)
So, we get a key character from an event terminal (as I16) and need to see if it matches a certain key.
Simple (as seen here)!
  1. Built it into an array with one element.
  2. Convert to U8
  3. Use "byte array to string" to convert to a string
  4. Compare resulting single character string with the desired string.
(...or we could just compare the Char directly. :D)
Message 333 of 2,635
(12,644 Views)
I'd be curious to see if the user does the same thing using the suggestion I had provided to use the Input Device Control function in order to recreate the program in 8.2 without an event structure (since the user has just the base edition of LabVIEW). Smiley Very Happy
Message 334 of 2,635
(12,642 Views)
LOL!!   I needed that laugh.  Good one Saverio.  😄
Also excellent posts by Christian..  🙂
Message 335 of 2,635
(12,633 Views)
altenbach,
Do you mean comparing the char directly with the ascii representation (i.. 43 for the "+")?
If so, although your suggestion is indeed quicker to execute, does the human factor of looking at the code and seeing what it does not come into it? I mean the "clumsy" code would still execute in a few femtoseconds!
I am curious as I have used code like this before!!! (If you can provide a slick way of directly comparing to the "+" character please do show)
Message 336 of 2,635
(12,586 Views)
I agree, speed is irrelevant here. The main point is diagram clutter. If you jump through so many hoops, another programmer might not understand why.
If you want to support the "human factor", you can start with a "+" string and convert it to the number outside the loop. This only needs to be done once. (see image)
(You could also simply show the label of the I16 diagram constant (61) and type e.g. "+ key" as label to make things easier to read.)
Message Edited by altenbach on 11-05-2008 01:18 PM
Message 337 of 2,635
(12,580 Views)
Message 338 of 2,635
(12,536 Views)
As one who is relatively new to LabView,I found this thread rather... enlightening.
Is there also a thread in which you have shared particularly elegant or clever (in a
good way) solutions you have come across?   You know, the kind of constructs
that make you say, "Oh!  I wish *I* had thought of that!"
Thanks and Best Regards,
-- J.
Message 339 of 2,635
(12,531 Views)
LabVIEW nuggets perhaps?
Message 340 of 2,635
(12,528 Views)
