BreakPoint
Rube Goldberg Code
Ben wrote:
Advanced PID fromthis thread
Ben, something's wrong with you link... 😞
Message 411 of 2,635
(11,931 Views)
Thanks Christian.
For the sake of completeness the proper link is here.
Q: What do you think about those fancy graphics in the diagram?
Ben
Message 412 of 2,635
(11,928 Views)
Here's another scary piece of code (from here😞
And in case you think this isn't RG code, I'm sure it could be done in a simpler way.
Nice one, Jim. I just hope you don't have to maintain that. 😄
___________________
Try to take over the world!
Message 413 of 2,635
(11,864 Views)
tst..
You'd be impressed at how often clients show us code just like that.
Now imagine an immense LV folder full of projects sharing files from all over the place, where there are many VI's that share the exact SAME name and everyone checks in & out of the one & only (unique) repository.  Now to make life more fun, picture the large immense labview folder (labview being the name of the folder) having 14,097 files (most of which are VI's) spread across 1579 folders and taking up 4.91GB on the PC.
Am I allowed to cry?
R
Message Edited by Ray.R on 02-12-2009 02:18 PM
Message 414 of 2,635
(11,862 Views)
My eyes! They burn!!!!
Message 415 of 2,635
(11,860 Views)
Our own projects folder had these issues where different projects referenced each other's files and had copies of vi.lib files, etc. At some point I wrote a program which went over all the projects, namespaced the VIs and moved things around so that this situation no longer happened. And we didn't even have SCC at the time.
I'm not sure I see the problem with this (other than using the wrong capitalization for LabVIEW). Our projects folder is probably not dissimilar in size (especially with Subversion creating duplicates of each file). And it's also inside a single Subversion repository, which makes the repository large, but makes it easier to handle. We could probably separate the projects into separate repositories, but then we'd have to automate some of the Subversion work (e.g. the initial checkout).
___________________
Message 416 of 2,635
(11,852 Views)
Ray.R,
As long as you cry in your beer, who cares?
P.S.  That's like the third username I've seen you use today.  Identity crisis?
Message 417 of 2,635
(11,841 Views)
centerbolt wrote:
Ray.R,
As long as you cry in your beer, who cares?  --  I'm off beer for a while..  😞   maybe I'll cheat on the weekend...  The beer is almost a year old.  Aged Stella
P.S.  That's like the third username I've seen you use today.  Identity crisis?  --  Yep.  Someone beat me to "RayR" so I put a period .  Bye bye JLV
tst,
Yep..  You've described what the folders look like.  They've evolved since LV6.0.  Imagine the surprise I had when I did a mass compile and was facing all the crosslinking issues.  I'm surprised to read that you have a similar large-scaled folder.  It's the first time I encounter such a mess.  I'm going to write a vi to clean things up.
R
Message 418 of 2,635
(11,824 Views)
Just to make it clear, it's not a single folder. It's a folder called "Projects" which has subfolders for each client and their projects. The entire projects folder is in a single Subversion repository. In the past, it had problems where different projects used VIs located in other projects and different projects had VIs with the same names, which was the problem the program I mentioned handled.
Hmm, maybe I should finally change my user name as well.
___________________
Message 419 of 2,635
(11,790 Views)
Over complicated error clusters (Multiple controls / indicators)
http://forums.ni.com/ni/board/message?board.id=170&message.id=393402
Message 420 of 2,635
(11,591 Views)
