BreakPoint
Rube Goldberg Code
Our first Rube Goldberg from the LabVIEW Idea Exchange for converting a number to a string of Boolean digits:
vs
Message 521 of 2,635
(12,573 Views)
Link.
Message 522 of 2,635
(12,565 Views)
Oops. Sorry about forgetting the link. Thanks, altenbach.
Message 523 of 2,635
(12,562 Views)
I just came across this:
How did that happen?
Message 524 of 2,635
(12,444 Views)
Please give the link where you find this. Maybe lot more will be there.
Mathan
Message 525 of 2,635
(12,432 Views)
Oh, I can't. I found it in some code I am currently updating for a customer, so it's not from any online source.
Message 526 of 2,635
(12,455 Views)
Perhaps He/she needed an inverter and had an unused Nand floating around on the diagram. I have used that approach several times in some of my circuits
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 527 of 2,635
(12,442 Views)
Coq Rouge is probably right.  This was very common in the days of TTL and CMOS logic logic where you had a board full of individual logic IC's.   You might need an inverter and have an unused NAND gate available.  Waste not, want not.
Message 528 of 2,635
(12,436 Views)
Maybe LV should have a special "Green" or ROHS icon for code which was created without deleting anything except wires.... Recycling is cool.
Shane.
Message 529 of 2,635
(12,427 Views)
Wayne.C wrote:
Coq Rouge is probably rightThis was very common in the days of TTL and CMOS logic logic where you had a board full of individual logic IC's.   You might need an inverter and have an unused NAND gate availableWaste not, want not.
This was before my time. But I have heard the 7400 NAND gate circuit was the cheapest logic circuit around. So it was actually more cost-effective to only use NAND gates. Then I went to technical school we still had to learn how to make logic with only NAND gates.
Message 530 of 2,635
(12,417 Views)
