BreakPoint
Rube Goldberg Code
@grahamwebb wrote:
Hi, this is my proper profile (and a testament to my lack of memory!)
I'd like to present this code for ridicule consideration as a Rudy Goldberg construction. It's one of those "I'm sure there's a better way, but I've started now so it will do".
A previous sub-vi searches for numbers and strings in a continuous stream of data (in a non-LabVIEW xml format), this ties them together.
Just a thought, after my eyeballs cooled.
Jim
Message 841 of 2,635
(11,593 Views)
I really like it when people pay attention to block diagram neatness. Absolutely beautiful wiring job!
LabVIEW 2012
Message 842 of 2,635
(11,572 Views)
- But that doesn't handle the special case "SACRUM", putting the contents of that VI or even all of the common code into subVIs would really increase readability to start with.
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 843 of 2,635
(11,519 Views)
A spanner has been added into this vi's works this morning, because I need to filter each channel. What was a curiosity has become today's work!
Message 844 of 2,635
(11,514 Views)
Coloring rows of a table according to a field value can be done in many ways. Here are two...
(seen here)
Message 845 of 2,635
(11,463 Views)
(seen here)
Maybe my coffe is not working but...
shouldn't everything after the "Serch 1d array" be in a case structure driven by the index returned by the Search... where the code shown is in the default case and there is nothing in the "-1" case?
Ben
Message 846 of 2,635
(11,441 Views)
Yes, the code is just a draft. In the example data given, there are no field values that don't exist in the comparison, so it is not needed. We seem to be dealing with a limited set of possibilities.
However, your code suggestion is still flawed. For correct operation, we still would need to feed the default color in the -1 case, because the row could have had an assigned color from an earlier field value. The color needs to be re-written no matter what.
Even if we want to deal with that possibility, we still don't really need a case structure: FOr code simplicity, we would just add a "+1" before wiring to the index and shift the color lookup array up by one index, with index zero now being the default color. 🙂
(If the table is big, there are other issues. For example we should probably defer panel updates during the coloring operation. If only very few fields should get colored, we would do a pass coloring the entire table with the default color and then selectively update only the few rows with "special" data. Here, your "case" suggestion would the the way to go. 😄 If we know the typical data, we can always finetune. Every situation is different.)
Message 847 of 2,635
(11,413 Views)
http://www.youtube.com/watch?v=Ntu7iHmKxDg&feature=player_embedded
Any other halo players out there?
Tim Elsey
Certified LabVIEW Architect
Message 848 of 2,635
(11,404 Views)
I don't want to rube you the wrong way Christian but I understood the rule of your thread here that the un-rubed version had to be functionally equivelant.
Take care,
Ben
Message 849 of 2,635
(11,376 Views)
That's sometimes hard to prove, especially since I did not shows the other cases of the case structures. 😉 I don't think such a rule can be strictly enforced. Many examples here behave slighly differently for edge cases. If anything, the suggested alteratives are often less buggy or add functionality. 😮
In this case, the code fragments were equivalent within the confines of the example data. Good enough for me. 😄
Message 850 of 2,635
(11,372 Views)
