BreakPoint
Rube Goldberg Code
So, while working with a "python" guru yesterday I asked:
"Did I read this right?--
IF value !=TRUE
      statement1
      value==FALSE
So, if it is false do other things and make it false again?" line 234 of main.py disappeared instantly.
The point? R-G is not LabVIEW dependant.
Message 961 of 2,635
(11,703 Views)
Booleans, schmooleans. I like enums, and you're going to like them too!
from here
Message 962 of 2,635
(11,678 Views)
@altenbach wrote:
(Maybe I am completely misunderstanding the answer here, but the question was how to run a loop indefinitely).
Q: How do you loop a problem indefinitely?
A:  "Compare to infinitiy. The positive infinity block is in the numeric section. The greater than comparison is in the comparison section. Compare something to infinity and wire the output to the stop icon in the while loop found in the structures section."
Really!?
Well that should make the loop go longer because the boolean constant will eventually decay. By continuously comparing a value with infinity the programmer is taking advantage of the Quantum Zeno effect to ensure that the loop does not stop. Ever.
LabVIEW 2012
Message 963 of 2,635
(11,662 Views)
@Jeff Bohrer wrote:
@SnowMule wrote:
Doesn't get any more efficient than that. :lol3
no, it does not.  write LabVIEW- post it to the forum- Christian removes all the unnecessary gyrations in your R-G code and it works.  What other development enviornment has that optomizer?
Now all we need is a sub-vi to do that programatically 🙂
Message 964 of 2,635
(11,601 Views)
I would settle on a Nugget by Christian Titled
"How I Approach Optimizing Code - Musing by One of the Worlds Best Wire-Slingers"
So what would it take Christian?
Can we bribe you with Kudos? Are you interested in an old "NI.com/exchange" coffee mug? Or maybe my collection of LTR publications?
Ben
Message 965 of 2,635
(11,582 Views)
Interesting use for typecast, seen here. 😮
(guess it indexes out the first element)
Message 966 of 2,635
(11,535 Views)
It looks prettier than the AND all array elements
Message 967 of 2,635
(11,493 Views)
Does index first element.  I had to try
Message 968 of 2,635
(11,471 Views)
The autor seems to have come up with this "solution" because the case structure would not accept a boolean array at the selector terminal.
QUOTE:
"I am getting boolean array which i want to connect to case terminal of different type. So, that is the only reason i converted that 1D array to scalar value by typecast."
While the typecast function can sometimes do magic, this is the first time where it was expected to read the programmers mind and somehow process the entire array and digest it into a single boolean that somehow reflects the contents of the original array in a meaningful way. 😄
This is another one of those examples where, one at a time, a randomly selected primitive is thrown in, until the wire is no longer broken. At this point, the code must be sound. Darwin would be Proud!
Message 969 of 2,635
(11,457 Views)
I would never have expected that..  That's truly remarkable (or extremely lucky).
Maybe someone should suggest that the Case Structure takes boolean arrays at its input.  It would automatically AND all the elements..
😉  (I had to put a smiley somewhere)
Message 970 of 2,635
(11,432 Views)
