BreakPoint
Unable to control myself from Code cleaning !
I also have the habit of saving the VI more often. Not only just save, Ctrl+Shift+Save and I started doind all the other applications as well. Many times I get a pop-up window when I try to do the same with MSWord.
Message 11 of 21
(6,273 Views)
@crossrulz wrote:
I am so bad that I usually clean up somebody's diagram just to figure out what they are doing.  I also created a few shortcuts to help me clean up.  And my number one righ-click menu that I use is "Clean Wire".
Oh really....
It seems that I may have found a way to cleanup my code without me putting in any effort.
So uh crossrulz...do you uh...want to look at my code *whistles innocently*
Message 12 of 21
(6,238 Views)
@Hornless.Rhino wrote:
Oh really....
Tim didn't mention that he review the code for free Smiley Wink
Message 13 of 21
(6,228 Views)
Oh really....
That is correct.  So would it be easier to go through the purchasing process or fix your own code?
Message 14 of 21
(6,215 Views)
P@Anand wrote:
There are many situations where I have to develop code within short time, but I am not able to control myself from cleaning the BD.
From some of my fellow collegues I was advised not to care about the wire bends and other stuffs and complete the code. Later part we can cleanup the code, but I am not able to follow this.  Even when I check the code of others and if I see wire bends and mis-alignment I start correcting them.
Feel free to post your opinion.
I'm the same way...
Especially when I work with others on the same project.
We do not seem to be the only ones..  That alone should count towards a CLD!
Message 15 of 21
(6,173 Views)
I do this too. Compulsively. Its a major psychotic obsession.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 16 of 21
(6,094 Views)
It bit me big time recently. I had inherited some code, was going through it trying to figure how it worked and was unconciously straightening wires, etc. I, without thinking, corrected some spelling errors (for two years, following this programmer, I have managed to resist this), and two weeks later, when we tried to run final tests on 80 parts, found that their initial test data (necessary for the final test) had not been saved in the local results database. It took a while to find, but, ummm, the unconcious corrections and meant that the initial test data did not match with the existing database field names. Doh!  Thankfully we had enough time to rerun the first tests (after correcting my corrections) and then run the final tests to get the parts shipped.
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 17 of 21
(6,073 Views)
Thats why I always have a backup before start checking the code, so that I can replace and get rid off the mess I create by cleaning Smiley Wink.
Message 18 of 21
(6,044 Views)
It's called source code control!
Message 19 of 21
(6,022 Views)
Manual source code control Smiley Wink
Message 20 of 21
(6,014 Views)
