BreakPoint
Why some people say Local Variables are bad...
No comments...
Message 11 of 396
(17,562 Views)
The loop will never stop.. Notice that "Acquire Data" is wired to Continue if True, and it's in the TRUE case selected by...  (drum roll...) "Acquire Data"!
Message 12 of 396
(17,560 Views)
All values passed by Locals...  or to make matters more fun... Globals!!
Message 13 of 396
(17,557 Views)
JoeLabView wrote:
This liks like an Aztec Pyramid from above. Let's call it the Aztec Coding style. :D
Message 14 of 396
(17,556 Views)
Joe LabView:  You need to find out who the authors of these examples are and stop them from proliferating any more code.  They are giving Labview a bad name.
- tbob
Inventor of the WORM Global
Message 15 of 396
(17,547 Views)
LOL!! yes it looks like a pyramid..  And yes, the authors are within the thread they were found.. just follow the link.
Post any examples you find of Locals abuse..!!  or Locals causing headaches!
Message 16 of 396
(17,537 Views)
Well, it seems that this thread is obviously slanted to the "locals/globals are bad" side. Perhaps for balance we need a "here's good ways to use locals & globals" thread.
Here's a recent entry.
Message 17 of 396
(17,528 Views)
edit - whoops, there's a whole second page
Message Edited by JeffOverton on 05-22-2008 02:05 PM
Message 18 of 396
(17,521 Views)
Thanks smercurio,
Yes, it is slanted...  The purpose is not to say that they are bad.. nor that they are good..
It is simply to show that in Labview, it is a common source of errors..  Mostly due to bad usage of Locals.  Same can be said with any syntax of a programming language.. 😮
If people treated Locals with respect (no abuse), then ... well... we wouldn't have to fix so much code.. 😉
However, the reason why the thread appears slanted is with the purpose of the thread, as depicted by the title.  🙂
RayR
Message 19 of 396
(17,512 Views)
Multiple Locals and Multiple Loops..  A mix for success..
(from http://forums.ni.com/ni/board/message?board.id=170&message.id=111134)
Message 20 of 396
(17,486 Views)
