BreakPoint
fizbuzz - a simple coding challenge
Woo! i can Smiley Happy again!
I quite enjoyed this little challenge (compared to some of the mountains I have to climb at work!)  perhaps this could be a regular feature?
I'm sure it'd improve my coding (and others) to see some different approaches to problems.
"If anyone needs me, I'll be in the Angry Dome!"
Message 11 of 41
(10,972 Views)
Why does everybody use so much duplicate code for the two Q&R operations. Simply divide by an array of [3,5]! Only one Q&R needed. 😮
Case structures are for wimps, so here's a solution that does not hide any code. 😄
Spoiler
Message 12 of 41
(10,969 Views)
A slightly better version of my first attempt then:
Spoiler
-CC
p.s. what do case structures have to do with Dark Matter? (Wimps) Smiley Wink
Message 13 of 41
(10,940 Views)
I like these small challenges, learned about the  Q&R with array 🙂
however the string conversion and replace array approach is executing worthless in 7/15*100 %
Greetings from Germany
Henrik
LV since v3.1
Message 14 of 41
(10,928 Views)
If the problem had been to do it for all possible I32 integers and as fast as possible, I probably would have coded it quite differently. You need to find the right balance.
This is sufficient for the current problem. 😄
Message 15 of 41
(10,924 Views)
I haven't tested it for speed, however I wanted to avoid two quotient&remainder vis
I was referring to your first solution.
Closer to a TTL logic 😉 using shift registers instead of Q&R (Hey, I started soldering before programming 😉  and still miss the triode.vi 😄 ) , where is the obfuscation?
Henrik
LV since v3.1
Message 16 of 41
(10,920 Views)
@P Anand wrote:
@Even Deejay wrote:
A nice task I hope I solved without any Rube Goldberg codeSmiley Happy
Still small thing you have that kind. You could have used Equal2Zero.png instead of Equal2Zero - 1.png. Smiley Wink
I enjoy reading these type so threads as well.
In my minds eye, I would prefer to find Even's approach with P Anand's mods. It is obvious "at a glance" what the code does. The other approaches are like trying to read one of my "quicky-replies". Yes there maybe an asnwer in there but you hvae to think to figure it out.
Thanks for the entertainment!
Ben
Message 17 of 41
(10,856 Views)
Thank you very much Ben for this kind of reply to my thread. Smiley Happy
Message 18 of 41
(10,854 Views)
here is my variation
Regards
Ray Farmer
Message 19 of 41
(10,798 Views)
Since the interview was joined by marketing and the project leader, the optics was switched to silver and more features had to be included.
Who needed the progress bar (followed by a slow down to make it visible!)  couldn't be reconstructed by the protocol 😉
Henrik
LV since v3.1
Message 20 of 41
(10,777 Views)
