CSLUG - Central South LabVIEW User Group (UK)
Network Availability Check
Hi Richard,
Thanks for converting that over. I`m getting an error when I run this, `OS not supported` , would imagine its because I`m running a 64 bit machine and windows on my dev machine. I`ll try and test it on a 32bit system.
Cheers,
Nick
Message 21 of 22
(1,524 Views)
If you remove the default case, and make the OS==Win case the default, it also works.
Message 22 of 22
(1,524 Views)
