Certification
CLAD Preparation exam/ Hardware Section/ Question n°7 How can that be possible ??
Hi
I can't understand how the good anwser is C ??
I tested all the VIs and the only one which outputs values bigger than 4 is B. But in the preparation guide the awnser is C.
Can anyone explain to me why ??
Question in the picture below.
(6,617 Views)
Accepted by Oussama_Zaidi
"Which VI will only output all channels that have a value greater than 4 in them?"
A technically outputs all channels, just empty data for those with values less than 4.  The requirements imply that you should not output anything for those who do not have a value greater than 4.
B and D do not output waveforms (the datatype).  They just output arrays.
C is using a conditional terminal to output only the waveforms whose max value is greater than 4.  So C is obviously the answer.
Could you share your code so we can see if you did something wrong?  Or maybe you are confused about which letter goes to which answer (it has gotten me a few times with these exams)?
(6,604 Views)
Thank you for your help.
I didn't understand the question. Now it is clear for me.
(6,594 Views)
I created answer C in LabVIEW, however, the waveform still shows all data points. Shouldn't it only show values greater than 4? See my attached code (I have LabVIEW 2018).
(5,604 Views)
No, it will retain all waveforms where at least one value is >4. All waveforms that match that conditions are fully retained.
(5,596 Views)
I'm still a little confused.So, as long as one data point is >4 in a single channel, all of the data points in that channel will show on the graph?
(5,592 Views)
That is correct.
(5,588 Views)
