Certification
CLD 16
How to create four booleans on the left?
and is the close reference necessary?
is there another easy way to initialize the front panel?
(2,985 Views)
Those are references. To create the control reference, right click >> create >> reference.
I'm not sure if close reference does anything here.
You could use linked property nodes, but when you are doing similar things to many controls, it's easier to use an array with an unlinked property node.
(2,975 Views)
Thanks so much!
(2,953 Views)
