Certification
CLD 5 practice
Do the data type have to be " hard coded'? I don't understand the "hard coded"
also what are the complications of using zero based indexing??
Thanks so much
(3,522 Views)
Accepted by topic author idjuven1
For the first question I am not sure I understand the "hard coded" either. My guess is that the cluster has to be "hard coded" because its structure won't change at all.
For your second question, just look at the solution, the comment about the 0-based index is pretty clear 🙂
CLAMaxime -- Kudos are a great way to say thank you
(3,514 Views)
