Certification
CLD 8 CSV file
I did  it as the enclosed file,
however, the solution contains an additional case structure with "error", " no error" outside the for loop..
could anyone explain the role of this case structure?
will I lose point for my solution?
(3,810 Views)
Accepted by topic author idjuven1
That's usually a good practice to have that Case Structure around the code if it is meant to be used as a subVI. It would prevent your code from executing if there is an error as input (like most of the subVI in LabVIEW). But it all depends on the specifications and your goal. In some cases not having the Case Structure is fine.
I am really not sure you would lose points but that's a good habit to do it like that anyway.
Where you would lose points in my opinion is for documentation and style. Try not to bend your wires, place nice comments, etc. The goal of those exercises is not only to work on the functionality but also your style within a given time frame. It is cool if you can tackle that problem in the xx minutes imparted, but it is even better if you are able to tackle it in style with good practices. Think about it : documentation and style are 25 easy points out of 40. So train for it too 🙂
CLAMaxime -- Kudos are a great way to say thank you
(3,809 Views)
thanks so much!
(3,799 Views)
For the sake of the CLD, yes you want the error case structure.  In reality, it actually helps zero to none and can keep the compiler from making some optimizations.  So I rarely (as in almost never) have a case structure around my code in subVIs.  The primitives already do not run if they get an error, so just let them continue with that.
(3,790 Views)
