Certification
CLD Question
hi everyone
if someone fail in passing the CLD certification exam , what is the periode that he need to wait to re-take the exam?
thanks
Message 1 of 9
(6,069 Views)
Accepted by topic author mon3am
You can attempt it twice in 6 months. If you are retrying it, I believe you can get 50% off by emailing the certification team.
See page 3: https://www.ni.com/pdf/custed/us/cert_faq.pdf
Message 2 of 9
(6,046 Views)
thank you gregoryj
Message 3 of 9
(6,042 Views)
I am going to take up CLD next month. Any tips or tricks to reduce the time for development.
The practice exam takes more than 4 hrs. I have heard that the actual exam takes more time than practice exams.
Bharath
Thanks & Regards,
Bharath Kumar
GCentral
Message 4 of 9
(5,846 Views)
Know how to quickly bring up your framework of choice, either from memory or from one of the NI project templates. It will be good to have 2 or 3 in your head and choose the one that best completes the problem, though a state machine is often a great place to start.
I don't know if the actual exam is harder, but I was definitely more nervous on test day. I was required to bring my own laptop for the exam, but I was not used to the laptop keyboard, so I brought a USB keyboard and mouse as well 🙂
Message 5 of 9
(5,838 Views)
@பரத்_குமார்(bharathkumar) wrote: Any tips or tricks to reduce the time for development.
QuickDrop and the shortcuts in it.  There are even default shortcuts as of LabVIEW 2016.
GCentral
Message 6 of 9
(5,834 Views)
Hello Gregory,
Architecture wise, state machine has been removed from template . i have seen .ini file read and write from examples, which i am planning to use. Any other I can use from examples??
Talking about Nervousness, Even thinking about the time duration scares me Robot Sad
Thanks & Regards,
Bharath Kumar
GCentral
Message 7 of 9
(5,817 Views)
Hello crossrulz,
Thanks for the tip. yes I am aware of the shortcuts.(thanks to my trainer ).
Any tip like How i should handle the time.
Thanks & Regards,
Bharath Kumar
GCentral
Message 8 of 9
(5,815 Views)
Hello Gregory,
I was using the JKI state machine a lot around the time of my exam, so I used this blog to help recreate it quickly. With some practice you should be able to make it in about 10 mins.
http://blog.jki.net/community/pass-your-cldcla-exams-the-jki-way
Message 9 of 9
(5,792 Views)
