Certification
CLD Success Package
Is the test using LV 2012? Has it changed yet to 2013?
I have been using 2012 for the past year.
Message 11 of 30
(14,831 Views)
If you take the exam at an NI center, it will likely have 2013.  But that shouldn't hurt you at all.  Everything is still pretty much where it was before.
Message 12 of 30
(14,821 Views)
Hi, I would like to mention a (small) coding mistake in the solution of CLD 11. When you open the solution and navigate to the Error Check of the producer you see this:
2013-12-06 15_09_57-CLD 11 Producer consumer events solution.vi Block Diagram on CLD 11 Producer Con.png
So after a diagram cleanup of this section it expands to this:
2013-12-06 15_13_48-CLD 11 Producer consumer events solution.vi Block Diagram on CLD 11 Producer Con.png
I don't know what the intention of the original programmer was but I guess he/she mend this:
2013-12-06 15_16_00-CLD 11 Producer consumer events solution.vi Block Diagram on CLD 11 Producer Con.png
Edit: a bit nore scrolling to the right (error handler) gave me this beauty:
2013-12-06 15_20_33-CLD 11 Producer consumer events solution.vi Block Diagram on CLD 11 Producer Con.png
Message 13 of 30
(14,620 Views)
That is actually a conversion from the old Merge Error function.  If you look in the VI properties as soon as you open the VIs, you will see that they were written in LabVIEW 2009.  The new(er) Merge Error that expands and is way faster was done in 2010.
Message 14 of 30
(14,617 Views)
@crossrulz wrote:
Ok that explains a lot since the error is twice in the VI and why they are alligned so nicely on the block diagram. It could be a idea to mention this in the "CLD success package users guide" so other users are aware of this.
However, next I'm wondering if the converter in LabVIEW shouldn't convert this to the 2012/2013 version instead of this strange edition.
Message 15 of 30
(14,614 Views)
Your space bar may be broken.
@Cust_Cert_NI wrote:
That is a result of down converting as mentioned.   This occurs because we down copnvert theVI'sto , inthiscase, 2009.   Asapolicyforconvenienceto ourcustomersweprovidematerialsonlineinaversionthatisthreeversionsbehind.
 Or, maybe, your thumbs...
Jim
Message 16 of 30
(14,586 Views)
Hi,  repost
That is a result of down converting as mentioned.   This occurs because we down covert theVI's to , in this case2009.   As policy for convenience to our customers we provide materials online in version that is three versions behind.
Mark Ramsdale
Program Manager & CLA
Global Demo and Equipment at National Instruments
Message 17 of 30
(14,579 Views)
(That's why I only use two fingers when typing)
Message 18 of 30
(14,563 Views)
Just want to say that I found the Sucess Package a great help. I take the CLD exam in January, and having failed it last year found feel that I am in with a better chance having worked through the exercises.
Going to watch the videos next then try some of the sample exams.
Thanks Helen
CLD, CTD
Message 19 of 30
(14,550 Views)
Hi Helen,
Thank you for the feedback. We're glad you find it helpful!
Cheers,
Daniel
Daniel Hays | Test Software Business Manager
Message 20 of 30
(14,547 Views)
