Certification
First Time Finishing a CLD Practice Exam!! (CarWash)
No i'm not trying to judge. I was just curious about how much time it's usually needed.
My Channel: https://www.youtube.com/@LV_Lab
Message 11 of 18
(1,995 Views)
You only get 4 hours. If you need more then 4 hours, you'll loose points on functionality, documentation or style...
How long it usually takes? 8-12 hours. So you need to double or triple your efforts for 4 hours Smiley Very Happy. Seriously, work hard right from the start, you need to make every second count.
Message 12 of 18
(1,989 Views)
I have to think the OP is not spending all day on one run-through.  😉
Bill
CLD
(Mid-Level minion.)
Message 13 of 18
(1,979 Views)
That is a training strategy: get things working with good quality, then work on improving the time to make it..
Message 14 of 18
(1,975 Views)
@billko wrote:
As far as I can see, you get all the points for functionality, but if I were to be nitpicky, I would say you need to give feedback to the customer that the high pressure wash was selected.  It's not that difficult to do - just set the button value to false on startup.  The idea is not to startle the customer.  😉
Note:
Instead of those humongous free labels that you have describing what is happening in each diagram of each structure, you can righ-click on the structure and enable submenus.  This will give you a space right under the selector (if case or event structure) or just right under the top (sequence structure, FOR loop, WHILE loop).  Makes it nice n tidy.
PASS.  Easily.
Thanks Bill!  Great feedback and suggestions.  Thanks for taking the time to look at it.
Studying for CLA.
LabVIEW, inherit from social media habits!
Message 15 of 18
(1,966 Views)
Exactly, at first I found my self unable to finish the test in a day, then I got closer to the 8 hour mark.  I slowly cut down each test as my mental efficiency improved over time.
I found that on this run, writing pseudo code at the start may have actually shaved an hour off my time.
Studying for CLA.
Message 16 of 18
(1,963 Views)
Just for reference: those things are called Subdiagram Labels. Right click->Visible items->Subdiagram Label.
Good advice though!
Message 17 of 18
(1,960 Views)
Good advice though!
I must have been half asleep when I wrote that.  😄
Bill
CLD
(Mid-Level minion.)
Message 18 of 18
(1,944 Views)
