01-10-2017 12:29 AM - edited 01-10-2017 12:38 AM
Most tricky CLAD questions list is given below.Please give your answer with explanation.
01-10-2017 12:47 AM - edited 01-10-2017 12:48 AM
Apparently they are all "Most Tricky" as they are in alphabetical order.
01-10-2017 05:58 AM
01-10-2017 09:11 AM
This looks suspiciously like homework.
Perhaps you should provide your opinion first for others to expand upon?
Just a reminder - posting exam material is prohibited by the NDA and punishable by removal of the certification and expulsion from National Instruments Certification Program.
-Nate
01-10-2017 09:34 AM
I don't know the origin of all of these questions but several I have seen on the practice CLAD, or CLD-R exams. I'll admit there are some that I don't know with 100% certainty. Lets see if I can put in my answers.
A) E - Code is not generated there is no scripting.
B) 1 - Poor question as a state machine could be a valid solution, and I'm not sure a Simple or General VI is defined as anything specific, is is a subjective answer if these terms aren't defined.
C) 4 - You can have as many controls as you want but might have no inputs terminals on the VI.
D) 4 - Not sure, but I've never heard of a Modular Node.
E) 2
F) 2 - Not really sure I don't use units
G) 2 - Again I don't use units
H) 1? - Again I don't use units
I) 5 - Never used the full but I assume it can make a polymorphic
J) 7 - Never used the basic but I assume it can make a polymorphic
K) 11
L) 2 - But by definition an instrument that doesn't exist could also be a virtual instrument. Poor question.
M) 13 - Again I assume other editions can make polymorphic VIs but I've only ever used professional.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-10-2017 10:12 AM
If those are CLAD questions, what a waste of time. Those questions don't prove anything about your ability to code in a language. That's like asking you to tell what day of the week that the Declaration of Independence was signed. Who cares?
01-10-2017 10:16 AM - edited 01-10-2017 10:21 AM
A few more questions:
1. What color was George Washington's white horse?
2. In what year did the War of 1812 take place?
Get those right and you can be a qualified, certified history teacher.
01-10-2017 10:25 AM
01-10-2017 10:34 AM
I haven't taken the exam, but knowing NI, I know that these aren't questions on the exam. I was being a litle facetious to show the obsurdity of the question. ![]()
01-10-2017 10:58 AM - edited 01-10-2017 10:59 AM
@Nathanael wrote:
These are not questions on the CLAD or CLD-R. I'm not sure where they have been sourced from.
I have absolutelly seen some of these on example CLAD exams several years ago. I taught a LabVIEW class at a local college and used them for a couple quizes. A quick search found at least one of the questions on an example exam, but several others I believe I've seen before too.
