Certification
Timer with pause, no polling
Did someone develop a timer with pause using events to avoid polling when the timer is pausing ?
(2,641 Views)
Seems trivial. What have you tried? (... and why do you think polling is bad?)
(2,629 Views)
What's the use case? Whenever I want a timer, I want it in a SubVI that I can check periodically to see how much time has elapsed. Is that what you want? Or do you want a user interface that just works like a stopwatch?
(2,621 Views)
