Continuous Integration
NI LabVIEW CLI: Call to VI Analyzer
I'm trying to call the VI Analyzer through the NI LabVIEW CLI.
Documentation and example can be found here:
https://www.ni.com/docs/en-US/bundle/labview/page/predefined-command-line-operations.html
So I make a new NI Analyzer task manually, that I want to call from the command line.
LabVIEWCLI -LabVIEWPath "C:\Program Files (x86)\National Instruments\LabVIEW 2018\LabVIEW.exe" -OperationName RunVIAnalyzer -ConfigPath "C:\Git\0000 Test For Delete\analyzefile.viancfg" -ReportPath "C:\Git\0000 Test For Delete\output.html" -ReportSaveType "html"
However, this just throws an error
Operation output:
Error Code : 85
Error Message : Scan From String (arg 1) in RunVIAnalyzer.lvclass:ParseArgumentsCore.vi->RunVIAnalyzer.lvclass:ParseArguments.vi:2800001->RunVIAnalyzer.lvclass:RunOperation.vi:5910001->CoreOperation.lvclass:CallRunOperation.vi:4230002->ExecuteRunOperation.vi:5250001->ExecuteOperation.vi:6900002->ExecuteOperation.vi.ProxyCaller
An error occurred while running the RunVIAnalyzer operation.
RunVIAnalyzer operation failed.
Any idea what is wrong?
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(5,741 Views)
Accepted by A.E.M
Within ParseArgumentsCore.vi there is a scan from string that converts the -ReportSaveType argument. Here is the block diagram:
And here are the options for the enum:
You need to match the case exactly, or else the scan from string will fail.
Would be nice if they had mentioned that in the help docs. Edit: Even worse! There's an example in the help docs that use 'html' in all lowercase!
Nathan Murphy
NI C Series Modules Product Manager with an expired CLA
(5,719 Views)
Thanks, you are absolutely right!!
Yeah, I just copied the example which didn't work... Hehe...
Best Regards
Alex E. Munkhaus
System Engineer
(5,691 Views)
