Continuous Integration
The LabVIEW Continuous Integration Project
Hello all, I have just started testing the Continuous Integration Project. I configured the Jenkins server and built the LabVIEW CI service as described in the documentation tot his project. But when I try to test the example build, I will always receive the error 500. I see the LabVIEW CI Service change from Idle to Running. A VI 'Hold Job in Memory' pops up, followed by another window 'Logger' (?). But that's all. Shortly after this the job teminates with error 500. Can anyone give me a tip or hint how to overome this? The setup is a Win10 Pro OS with LV2018. Regards Heinrich
Message 71 of 71
(1,721 Views)
