Counter/Timer
10MhzRefClock as Trigger
Hello
I'm using a NI-USB 6343 device. I was able to generate 2 TTL signal with one is delayed from the other.
I'm using 10MHzRefClock as trigger. It seems to work.
Is it the right way to do so? (i.e. generate an internal trigger event?)
Thanks for any inisght!
(4,947 Views)
Hi nkhoa,
I reviewed your code and it looks good for generating an internal trigger event.
Best,
Hannah
(4,935 Views)
Thanks!!
(4,931 Views)
