Counter/Timer
Module and wiring for frequency measurement with Yokogawa flowmeters and a speed pickup
I need to measure the frequency output of three Yokogawa AXFA14G flowmeter and a speed pickup using a cDAQ module and 9188 chassis.  I am unsure of the best module and the correct wiring.
The Yokogawa meters that I have can provide a passive pulse output.  I have attached the wiring diagram.  The power supply must be less than 30VDC and 0.2A.  I expect to see frequencies up to 11,000Hz.
I also need to measure a speed pickup.  The speed pickup has three wires:  The power supply 5 to 15 VDC, the output signal (5V TTL) and the common wire.  I expect to see frequencies up to 4,000Hz.
I would like to read three flow meters and the speed pickup with one cDAQ module.  I would also like to power all four devices with one power supply.  I am unsure if the devices are considered sinking or sourcing.  I am unsure of the correct module and the correct wiring.
My options appear to be:
NI 9401.  Powering flow meters and speed pickup with a 5 volt supply
NI 9411.  Has a built in regulator.  I would have to be able to measure both device types as signgle ended.
If I only measure the flowmeters, I could consider using the 9423 (if the flowmeters are (sinking).
(4,800 Views)
It looks like the NI-9411 will work for your application the best
Ben H.
Systems Engineer
(4,782 Views)
