Counter/Timer
4 PWMs with 9472 module on 9174 chassis possible?
Hi there,
is it possible to generate 4 independent PWMs with a 9472 module on a 9174 chassis? In the past I already realized 1 PWM with a 9474 module (same chassis) using one timer of the 9174, so 4 timer = 4 independent PWMs?
Regards
cpschnuffel
(5,979 Views)
Accepted by cpschnuffel
There may be situations where you will need to utilize counters for gating/clocking, but basically you have 4 PWM channels with 4 counters.
Marco Brauner NIG
(5,973 Views)
OK, this confirms my assumption.
Thanks a lot!
cpschnuffel
(5,971 Views)
