Counter/Timer
555 Timer
Hello
Ive some problems with the 555 Timer. I'm trying to get an defined pulswidth signal out of a current signal.
My problem is the circuit should work with 0.25 to 1 Hz on the current signal.  I've got it running at 1 Hz but if i try to go lower the timer starts to get crazy.
im a really noob in stuff like that and happy with every little help Smiley Embarassed
i hope someone can help me Smiley Happy
thank you
toobi
(5,935 Views)
Accepted by tooobiCH
You'll get help if you post to the appropriate board. This is for NI counter products and you want the Circuit Design Suite board for Multisim. Repost or click on Options and request the moderator to move this.
(5,860 Views)
