Counter/Timer
6602 6612 differences
I have a project using a 6602 PCI to collect 2 arrays of time stamps of pulses from 2 encoders using DAQmx.dll i.e. .NET. c#.  In order to synchronize the 2 encoder tasks data for comparison, I create a "starter" task that is triggered by a digital edge trigger (a PFI).  Then I create a task for each encoder and make their digital edge triggers point to the output of the "start" task.  This is all working very well.  Now I have a new 6612 counter card and thought I could drop it in as a replacement, but instead I am getting the following error:
"The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<0>
Status Code: -50103"
What difference between the 2 cards could be causing this?  I have looked for differences between the 6602 and 6612 but have only found where 6612 can handle more instead of less.
Thanks for your time.
(2,893 Views)
Accepted by topic author MrSethT
They are interchangeable.  The same time I was swapping out the 6602 for the 6612 I accidentally changed one of the encoder tasks from a LowFrequencyOneCounter to a HighFrequencyTwoCounter.  It was just a dumb mistake.
(2,827 Views)
