Counter/Timer
Route Internal Clocks to PFI lines
I am trying to route an internally generated clock to various modules (6674T and 6584 specifically) via their PFI or clock lines.
I tried using NI-sync for the 6674T to no success. I tried doing whats listed in this article too https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019P3gSAE&l=en-US as well as this article https://forums.ni.com/t5/LabVIEW/6674T-clock-distrubution-via-DStarA-with-4-7966-FlexRIO-modules/td-....
Is there a straightforward way to route a clock (in this case instantiated/defined in the 6584 'library') to the other modules and such? When I use NI-Sync, I cant just pull the clock up as a destination for a trigger or source
EDIT: I have also tried this https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6OeSAK&l=en-US, but it appears out of date despite being updated Jan 14 2019. I dont have the DDCA options in io node as well as the images dont appear
Thanks!
Message 1 of 1
(2,384 Views)
