Counter/Timer
6602: Generating a pulse train with specified high and low levels
Looking at the 3 Counter-Output DAQmx Create Virtual Channel options, I don't see a way to set the low and high levels of the pulse train to generate.  Is there a way to specify the high and low level?  I am working with the Counter-Timer PXI-6602.
Melissa
(3,507 Views)
The high and low levels are dictated by the hardware and cannot be changed.  It's compatible with TTL logic, meaning that low levels are generally near 0 V and high levels are more like 5 V.  Rise and fall times are also specified as very short durations (sharp edges).
If instead you want to set the high and low TIMES of a pulse train, there are inputs available in DAQmx Create Virtual Channel that let you define the timing characteristics of a pulse train.
-Kevin P.
(3,503 Views)
