Counter/Timer
Issues with counters 3 and 4 on PCI-6601
Hi All,
   I am using counters 1-4 on the PCI 6601 card with NI-DAQmx 8.0 to generate continuous pulses in Labview  8.0. After I configure the counters, I can see the pulses going out on a scope. If I then configure other DIO lines as digital outputs, the pulses on counter 3 and 4 goes away. Counter 1 and 2 is  still okay. Has anyone seen this before. Somehow the configuration on counter 3 and 4 is changing when I try to configure other DIO lines as outputs? For configuration of continuous pulses I  am using the Pulse Train Gen.vi  from the DAQmx PWM Examples.zip folder from NI website minus the while loop and the DAQmx clear Task.vi. The Pulse Train Gen.vi include DAQmx Create Channel(CO-Pulse Generation Frequency).vi, DAQmx Timing(Implicit).vi, DAQmx Start Task.vi, and  DAQmx Is Task Done.vi. For digital outputs I am using DaQmx Write(Digital Bool 1 Line 1 Point). Any suggestions as to why counter 3 and 4 configuration changes and not counter 1 and 2. I need to have these counter going before I configure output lines.
Message 1 of 1
(3,313 Views)
