Counter/Timer
9411 to measure velocity AND count revolutions using index
I am using the quadrature mode for the 9411 on a cRIO and would like to count encoder (motor) revolutions in addition to measuring velocity.  Is there a way to capture the index pulse in a counter?
Thanks.
(6,538 Views)
Hi Choff,
Using the FPGA you can do this, you just need to measure the time between edges for the velocity and use a counter for the position.
Joe Daily
may the G be with you ....
(6,506 Views)
Can anybody Pls reply for this question?
(5,843 Views)
