Counter/Timer
About PCI6602.
Can i select by soft(CVI) differents SOURCE AND GATE for counter 1?i want select with GUI witch signal i apply to Source and Gate of my counter.
See attach file 6602.jpg Is this OK?
(3,471 Views)
Yes, you can select different source and gate PFI lines for each counter. Take a look at the NI-DAQ Help file. Start >> Program Files >> National Instruments >> NI-DAQ >> NI-DAQ Help. Goto the GPCTR_Change_Parameter function. Under the paramID ND_SOURCE and ND_GATE, you will see all the possible lines you can route to them.
Brian
(3,471 Views)
