Counter/Timer
How generate callback with a 6602?
I have two signals F1=585HZ and F2=76MHz.I use F1 as GATE and F2 as SOURCE to generate a pulse with a delay.
I must calculate this delay to change every 1/F1seconde.
Thanks.
(3,827 Views)
I would suggest using buffered pulse-width measurements with negitive polarity to measure the delay instead of the width. You can send the signal into the Gate of a counter and use the 80MHz internal timebase as the source. There are shipping examples with LabVIEW that can do this. Let me know if you run into any problems.
Brian
(3,827 Views)
Thanks bman,See attach file.
I want generate a pulse triggered by 585HZ with a variable delay that i want to calculate in a callback
synchronised with 585Hz(this delay is fonction of external parameter)
I use Labwindows/CVI and PCI6602.
SL
(3,827 Views)
