Counter/Timer
Benchmarks for Buffered Counter Input with X-Series Devices
Does anyone know the maximum transfer rate (using dma) for the x-series cards?
I'm looking for data simillar to the one in this link:
http://digital.ni.com/public.nsf/allkb/72A7E41EE5A8756A862571DA0076F1D7?OpenDocument
More specifically I want to know the transfer rate for the PCIe 6343.
Thank you,
Eyal
Message 1 of 10
(9,258 Views)
I've benchmarked 10MS/s on all four counters at the same time - this is for all X Series boards. I don't recall the CPU usage but it was relatively low on a single core machine. I mentioned this and more in this post - X Series is here – New Counter Features!
Cheers,
Andrew S
Message 2 of 10
(9,257 Views)
Hi Andrew,
Do you happen to know the transfer rate for just 1 counter? I'm currently using the USB-6210 which has a bigger FIFO (1024 ) but if the transfer rate is substantially better for the X series it might work out alright for my application. For 1 counter I get 1.2MHz transfer rate on my current card.
I'm using 1 counter for period measurements. My signal has occasional high frequency bursts which is the reason I need a big FIFO and/or fast transfer rate.
Thanks for the information,
Eyal
Message 3 of 10
(9,246 Views)
Accepted by Eyal_S.
For a single counter, I've benchmarked up to 20MHz. You can't achieve that on all four counters because of PXIe/PCIe bandwidth limitations (4 counters X 20Ms/s X 4 B = 320MB/s) but for a single you can achieve those rates. I didn't run it for an extended period of time, but at rates like this if we're going to get an overflow we'll usually get it pretty quickly.
Cheers,
Andrew S
Message 4 of 10
(9,232 Views)
Do you anybody know the benchmark results for one/four counters on NI USB-6356/6366. It is also X series but USB. Are the counters digitally triggerable for input operations?
Thanks.
LV 2011, Win7
Message 5 of 10
(8,357 Views)
Hi ceties,
I can't speak to benchmark figures but I actually just replied to another post of yours on the MIO board and mentioned that the X-series (among many other boards) DO indeed support triggering for counter input measurements.  I'm not sure whether the X-series handles it differently, but prior boards that supported triggering for counter input tasks required the use of an "Arm Start" trigger rather than the standard start trigger.
-Kevin P
Message 6 of 10
(8,352 Views)
I benchmarked 8MS/s on a single channel on a USB-6353 (should have similar performance to the USB-6356/66) with a buffered counter input task. This was only a 10 minute test on my Dell E6400 laptop ( Windows 7 32 bit, Dual core P8600, 4GB memory) so a sustained 24/7 rate is likely less. Also, I wasn't doing much with the data, just displaying it in an array. This is pretty much topping out USB streaming on this system (32MB/s) so I wouldn't expect to get higher. I wasn't running much else in the back ground (Explorer, Powerpoint, Lotus Notes) and CPU was at ~20%.
Hope this helps,
Andrew S
Message 7 of 10
(8,321 Views)
Hi Andrew and thanks for your time,
Just to be sure since I was not very clear - those 8MHz is the frequency of the input = how fast the TTL pulses were coming? And if you went higher with the freq you got a buffer overflow error, right?
LV 2011, Win7
Message 8 of 10
(8,318 Views)
Correct - I generated an ~8MHz counter output with one onboad counter and did a buffered edge count with that as the sample clock - same operation under the hood as a single counter frequency measurement. Anything higher I get buffer overflows. Notes, even at higher rates I was able to acquire some samples before getting an overflow.
Hope this helps,
Andrew
Message 9 of 10
(8,314 Views)
Thanks for the clarification!
LV 2011, Win7
Message 10 of 10
(8,291 Views)
